Format to Without Space Between Number and Unit
@paul_a_cardinale wrote:
@PhillipDBrooks wrote:
If units are used, you can use the following format for an SI formatted value
%_3{V}p
That moves the space, but doesn't eliminate it.  Also, it only works if the physical quantity is voltage; doesn't work for other physical quantities.
Besides Voltage, the {} also works for Gauss and Tesla
I don't have to use it often, but when I do, I appreciate the built-in Unit Conversion e.g. CGS to SI System
Message 11 of 31
(569 Views)
@Yamaeda wrote:
Unit agnoistic with space moved, but not suppressed.
Not unit agnostic.  It assumes that the unit is a single character (often it is not).
Right! I didn't think about that, you have to cut at space instead.
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 31
(546 Views)
It is not exactly what you mean (it does not use the unit of the numerical), but here is a univeral number formatter with units included. I use it to display all my numerical values. It also gives the number and unit separately. The caller then has an indicator for both the value and unit. This allows you to nicely align multiple indicators vertically.
Message 13 of 31
(448 Views)
Attempt 2 🙂
Qestit Systems
Message 14 of 31
(412 Views)
@Yamaeda wrote:
Attempt 2 🙂
never surrender ; )
Message 15 of 31
(399 Views)
@Yamaeda wrote:
Attempt 2 🙂
Good attempt, but unfortunately no space between numeral and unit appear, usually it should be "456 kPa", instead of "456kPa" (from Typography point of view).
Message 16 of 31
(378 Views)
Fun exercise in string manipulation. Here is a version that works for numerical values with a unit.
Kudos to @Yamaeda for getting the unit using the format string function. I didn't know it kept the unit in the output string!
Message 17 of 31
(370 Views)
When i went to school we often wrote it without space. It seems it's standardized to a space nowadays.
Qestit Systems
Message 18 of 31
(351 Views)
Hi Yamaeda,
"Nowadays" is atleast 30 years old (when I wrote my diploma thesis)!
That's the German regulation, I already linked to the NIST rules in message #2.
Message 19 of 31
(328 Views)
Then it turns to this:
Qestit Systems
Message 20 of 31
(324 Views)
