Freuqency measurement error
r.youden,
The solution of Jeff is the better soluition.
Mine is the lazy man solutionSmiley Very Happy, only use this if the problem only persists at the beginning.
Though recommend you to use Jeffs idea which is better overall
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
Message 11 of 15
(829 Views)
Hi Jeff,
Thanks for your answer. I think I understand what you mean now.
From the diapgram you drew when the VI is in error the handled output becomes True and the Numeric Indicator becomes 0 and the error output is cleared. I guess I need one of these routines per frequency channel. Also where do you recomend connecting the Handled and Numeric outputs within the VI.
I massively appreciate your help.
I have booked myself onto a couple of NI training days in January so hopefully I will become a bit more self sufficient with this sruff!
Thanks.
Richard
Message 12 of 15
(812 Views)
@r.youden wrote:
Hi Jeff,
About like this....
Message 13 of 15
(803 Views)
That's great thanks Jeff.
How would I create the Error handler? I guess that contains the case structure you showed earlier and that is made into the block... How would I go about that?
I guess that NI course can't come soon enough!!
Thanks.
Richard
Message 14 of 15
(794 Views)
the same way I remade it.   FROM the snipette.
Drag the picture to your desktop, drag it to a blank BD POOF!
(Kudos to anyone who can find the link to where I "Jinged" that in the last 2-4 months)
Add a icon and connect the terminals to the con pane
Message 15 of 15
(787 Views)
