‎05-17-2018
11:45 PM
- last edited on
‎01-09-2025
08:30 PM
by
Content Cleaner
Hi All,
I am working through this tutorial Distributing Applications from this NI Tutorial
http://www.ni.com/tutorial/3303/en/
My uncertainty at the moment is I am using LV2014 and when I look for the LV Run time engine which I believe should be installed on the target Computer, there pops up a number of Run time engines ,What is the correct Run time engine and does it need to be installed on the target computer.
I appreciate your help and directions I do not need an installer I just need an executable for my test team on the vehicle
Regards
QMESAR
Solved! Go to Solution.
‎05-17-2018 11:52 PM
A target can have any number or different runtim engine installed at the same time. If your executable was made in LabVIEW 2014, it needs the 2014 run time engine. See if it is installed, else install it.
‎05-18-2018 12:08 AM
Dear altenbach.
Thank you very much for the clarification .
Regards
QMESAR
‎05-18-2018
02:07 AM
- last edited on
‎01-09-2025
08:29 PM
by
Content Cleaner
Hi All,
I ran into a confusion with the Tutorial from NI web from here http://www.ni.com/tutorial/3303/en/
(1) The tutorial mention that you should enter the target name Tutorial.exe in the Target filename Text box in the
Information page ,in my LV2014 this text box does not exists .
(2)From the Source files Category I should select the Tutorial GUI.vi as the Startup Vi by selecting the add arrow next to the Startup Vi list box,again this list box does not exist in LV2014?
The question is this Tutorial older or newer than my LV2014 this Tutorial helps me in no way is there somewhere something that can help me just to make a executable of my LV project
I am more worried and concerned than a week ago when tutorial make people more lost then help then I am worried ![]()
Any help directions are highly appreciated
Regards
QMESAR
‎05-18-2018 02:41 AM
‎05-18-2018 02:56 AM
Hi GerdW
You most probably correct but in the Tutorial under Stand-Alone application points 1 &2 ,I do not have these settings when right clicking the Build specification ,Build specification select- New >> Application , Only have this I am sorry for my ignorance.![]()
‎05-18-2018 03:01 AM
‎05-18-2018 03:15 AM - edited ‎05-18-2018 03:16 AM
Hi GertW.
Yes this was the problem the company machine has the application builder installed however it was not activated ,I activated it now and the quick menu looks quite different ,This is clearly beginner novice issues
Thanks a million now it is good
Regards
QMESAR
