General Info Application Builder
Hi All,
I am working through this tutorial Distributing Applications from this NI Tutorial
 http://www.ni.com/tutorial/3303/en/
My uncertainty at the moment is I am using LV2014 and when I look for the LV Run time engine which I believe should be installed on the target  Computer, there pops up a number of Run time engines ,What is the correct Run time engine and does it need to be installed on the target computer.
I appreciate your help and directions I do not need an installer I just need an executable for my test team on the vehicle
Regards
QMESAR
Learning is an endless process but needs to start some where
Message 1 of 8
(4,050 Views)
Accepted by QMESAR
A target can have any number or different runtim engine installed at the same time. If your executable was made in LabVIEW 2014, it needs the 2014 run time engine. See if it is installed, else install it.
Message 2 of 8
(4,045 Views)
Dear altenbach.
Thank you very  much for the clarification .
Regards
QMESAR
Message 3 of 8
(4,037 Views)
Hi All,
I ran into a confusion with the Tutorial from NI web from here  http://www.ni.com/tutorial/3303/en/
(1) The tutorial mention that you should enter the target name Tutorial.exe in the Target filename Text box in the
Information page ,in my LV2014 this text box does not exists .
(2)From the Source files Category I should select the Tutorial GUI.vi as the Startup Vi by selecting the add arrow next to the Startup Vi list box,again this list box does not exist in LV2014?
The question is this Tutorial older or newer than my LV2014 this Tutorial helps me in no way is there somewhere something that can help me just to make a executable of my LV project
I am more worried and concerned than a week ago when tutorial make people more lost then help then I am worried Smiley Happy
Any help directions are highly appreciated
Regards
QMESAR
Message 4 of 8
(4,021 Views)
Hi QMESAR,
which kind of Build did you select?
Did you really chose the "Application (EXE)" build - or rather the "Source distribution" as it seems from your images?
Message 5 of 8
(4,003 Views)
Hi GerdW
You most probably correct but in the Tutorial under Stand-Alone application points 1 &2 ,I do not have these settings when right clicking the Build specification ,Build specification select- New  >> Application , Only have this  I am sorry for my ignorance.Smiley Embarassed
Message 6 of 8
(3,999 Views)
Accepted by QMESAR
Hi QMESAR,
then you miss the AppBuilder license!
Is your LabVIEW license allowed to use the AppBuilder at all?
Did you validate your license?
Did you check your license in the NI LicenseManager?
Message 7 of 8
(3,996 Views)
Hi GertW.
Yes this was the problem the company machine has the application builder installed however it was not activated ,I activated it now and the quick menu looks quite different ,This is clearly beginner novice issues
Thanks a million now it is good
Regards
QMESAR
Message 8 of 8
(3,993 Views)
