HEX String Range check
Hi
Please find the enclosed snippet.
Here i'm checking the range of Hex string. The result of the attached snipped suppose to be false. But it is giving the true value.
Kindly explain.
S Nagaraju
(5,184 Views)
Hi Sonti,
when using strings LabVIEW "tends" to alphabetically ("by dictionary order", my English isn't that good) use them for comparisons.
Your input value is between the range limits!
When you want to compare values you need to use numeric datatypes: convert your strings to numbers…
(5,179 Views)
Based on what condition its should be false?
Check for the Hex String to Numeric and Find the values of Input Strings.
(5,177 Views)
Hi PalanivelT,
If I convert the hex string to number, BFFFFFFF ==>  3221225471 (Upper limit)
                                                          81000000 ==> 2164260864 (lower limit)
                                                          810001 ==> 8454145 (Value)
For numeric data type the result will be false. But in case of hex string, how the range check is happening??
I have checked with the range between hex values 0 to F and i found the reliable result. What is the issue with this case??
Kindly explain.
S Nagaraju
(5,151 Views)
Accepted by Sonti_11532
Hi Sonti,
Did you read my answer?
Strings are sorted by dictionary order!
So your "810001" lists AFTER "81000000" and BEFORE "BFFFFFFF" in the dictionary…
(5,147 Views)
