How can I remove repeated elements in an array
I'm a little late to the party, but there's always the Unique Numbers and Multiplicity VI.  It may not be the fastest with regards to execution, but it's definitely the fastest to use!  Particularly when it comes to documentation- heh.
Edit- quick test on my machine using Altenbach's benchmarking VI has it pretty middle-of the pack for "mostly unique" arrays, looks like it's using a search-and-build algorithm similar to Apok's suggestion.  This does put it in the lead for "mostly similar" arrays though, presumably because the array that's being searched doesn't get particularly large.
This had me thinking, though- could this be done without using the search or sort functions? I put this together, and it suffers a lot for "mostly unique" or spread-out arrays, but it's actually a decent amount faster for mixed and mostly similar arrays (for positive integers) for up to about <array size>^5 (98% unique) in Altenbach's VI.  I'm pretty sure the limitation is coming from the unknown array size at the end as well as the use of the max/min function, but I've not looked at it too closely yet.
Edit again- I realized that the slowdown for extremely spread-out numbers is probably because the size of the allocated Boolean array scales (more or less) linearly with the spread of the search group, making the allocation at the beginning and conversion at the end that much more expensive.
Tom L.
Message 31 of 38
(3,563 Views)
Great. I knew there was some slack left. 😄
Yes, it performs poorly under certain conditions. It also would not work for e.g. DBL arrays or arrays containing negative numbers, so it is not very universal.
(Now we just need to wait for a version that uses variant attributes. :D)
Message 32 of 38
(3,553 Views)
0utlaw wrote:
On Windows 2013, you can get about 30% faster than your code by not using the conditional tunnel and applying some other tweaks.. On windows 2012, the difference is probably even more dramatic.(not tested).
A quick test using variant attributes shows the speed similar to ouadji's code, so that's not a real contender.
Message 33 of 38
(3,532 Views)
@ouadji wrote:
altenbach's method  slightly improved, slightly faster (altenbach_2)
No, this code is faulty! If all elements are negative and the sorted array contains a single zero at the end, that zero is discarded in error. Try it. 😉
Message 34 of 38
(3,505 Views)
A quick recap showing how to improve outlaw's limited version (LV 2013).
(Note that "altenbach" and "ouadji II" are indistiguishable here)
(I also show a simple draft using variant attributes that can probably be improved):
Message 35 of 38
(3,500 Views)
@altenbach : No, this code is faulty! If all elements are ...
yes, you're right, nice shot   Smiley Tongue  I have already fixed this problem.
Message 36 of 38
(3,485 Views)
So, I went ahead and modified Altenbach's improved Boolean traverse version so that it could parse negative integers as well; it's getting a bit Rube-ish, but go figure it actually got faster again (looks like about 20-40% on my machine) for some reason. This time I'm not sure why- perhaps I'm avoiding a run-time copy of some sort by using the case structures?  Ideas?
The false cases are just wired through- otherwise we shift the array so everything's positive and then un-shift it at the end.
Tom L.
Message 37 of 38
(3,456 Views)
It does not quite make sense that it should be faster, because it does basically the same thing (actually a little bit more ;)). But, oh well, that's the LabVIEW compiler. 😄 You should also make the new value default for the "Code" array control.
It is curious that the IPE is slower than "replace array subset". I guess it does a little bit more because it also has an inner output.
You can probably remove the case structure and do the adding/subtracting irrespectively. The penalty is not measurable, but we gain speed if e.g. all inputs are positive and very large, but they only cover a small range.
Message 38 of 38
(3,438 Views)
