How can I resize an array directly (without using reshape array)?
Hi everyone,
I have a porgam in which I am using an array as a command (with specific values that the user enters before running the program). By mistake, at the beginning I created a 4 dimension array (for instance), but I didn't know because I was only showing the first 3 values (not expanding the array to 4 or more). I would now like to change the size of the array from 4 to 3. I don't seem to be able to find an option (right clicking on the array) that enables me to do this directly. I don't want to use the "reshape array" icon, because this is not what I want to do. I hope I am clear enough.
Thanks for any help,
regards,
Marc
(3,711 Views)
Accepted by marc france
  • right-click the extra array element and select "data operations...delete element".
  • Now go to the menu bar and do "edit...make current values default"
  • save the VI.
(3,706 Views)
HI,
          If i have understood your question hope this helps you. If you want to change the size of the array right click on the array element and click Data Operations>Delete Element or if you want to do programmatically delete the particular element.
(3,700 Views)
ooops forgot the check element array options.... thanks a lot to both of you !
regards,
marc
(3,691 Views)
