How do I simultaneously scroll through two arrays by changing the index on one of the array
How do I simultaneously scroll through two arrays by changing the index on one of the arrays?
(3,511 Views)
Create property node for both
Choose index values
Set one to read and one to write
see attached
(3,506 Views)
Hi
I tried what you suggested but I want to do it for arrays of different type.
Can you please help?
(3,479 Views)
Should work for any type of array. What "types" are you using. Can you post an example?
(3,478 Views)
I am using a 2dimensional dbl precision array and a 1d boolean array.
If you have the solution can you please send a jpeg of the solution.
Thank you.
(3,473 Views)
I am assuming you wish only one of the dimesions from the 2D array to control the indexing of the boolean array.
In the attached example the index of the first dimension from "Array" controls the index of "Array 2" and the index second dimension controls the index of "Array 3"
(3,469 Views)
