How get a lvbitx, which is already compiled on another PC, installed on a new (similar) FPGA module 9146 (without recompiling).
Hey all,
How do I get a lvbitx, which is already compiled on another PC, installed on a new (similar) FPGA module 9146 (without recompiling).
I only gave the lvbitx file, not the whole project.
Can anybody help me with that?
Thank you in advance.
(2,834 Views)
Accepted by Bart_Aerts
What did you compile the bit file for?  Also a 9146?  Are you trying to use the bit file with the same version of LabVIEW?
If it is the same type of target and the same version of LabVIEW (or its runtime engine), then you just call the bit file with the Open FPGA VI Reference.  Otherwise you will need to recompile.
(2,826 Views)
