How to change a 6008
I create a VI with LV 8 for student edition, a 6008 and daqMX. It is very well
But if i use an other 6008 i have an error, it is not recognize.
Why?
Tanks
(2,810 Views)
The NI-USB DAQ devices will be seperated by theír serial number. That means that your DAQmx channels are logically conneced to a unique NI-USB 600x device.
Greetings
Steffen
(2,793 Views)
Yes, i belive it, but what can i do.
(2,781 Views)
Hello AéroTech,
The solution could be to save the different Hardware profiles with the different USB modules plugged-in. Ideally you should save the hardware profiles for each possible USB modules.
Hope it helps.
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(2,750 Views)
