How to convert binary data from the front panel controls into ASCII values?
I have seemed to run into a road block with how to convert binary values into ascii.
I created this .vi to save all control values into an .ini file and call them back when I am executing the .vi as shown in the attached file. The save button will simply save the data and cancel button will ignore all the current changes.
I would like to understand how to retrieve all the control values in ascii format, so I assign them into a global variable for later usage. I have been looking everywhere for a good reference document and I couldn't find one which would explain my question. I would be greatly appreciated if someone could point me in the right direction.
Sam
Message 1 of 10
(6,329 Views)
I think you picked some pretty old and way over too complex example. This is just much easier. Did you search in the forum and elsewhere how to properly use configuration files? This is one of the 10 most often asked questions in the forum. There is waste of examples in the forum and other places how to properly do it.
Sam_Sharp here gives some good ideas how to do it using the openG toolkit:
http://forums.ni.com/t5/LabVIEW/Saving-application-state-for-later-resume/m-p/3225945/highlight/true...
Message 2 of 10
(6,304 Views)
Thanks for giving me a different prespective on how to slove my issue. I have been seeking a simple way to save control values in the front panel for while now and you have shown me different method. In my main application, there are muliple VIs that I need to commence this process.
For my initial issue, I think I figured out the solution after trying out different things. I used the "Flattened String To Variant Function" to slove my issue.
Sam
Message 3 of 10
(6,274 Views)
Accepted by Sam2009
Do not reinvent the wheel, when there are ready to use solutions, for example:
https://www.ni.com/en/support/downloads/tools-network/download.reusable-vi-library-for-labview.html
Use the MGI Save & Restore Settings VI from the palette (for example it saves all settings modified in a Graph, very useful), and the MGI Save (Restore) Front Panel Data VIs (to save and restore control values in the Front Panel).
Here is an example:
Message 4 of 10
(6,252 Views)
Awesome. Thanks for your guidance. Most importantly, I will utilize your method by using the MGI library in my application.
I just wanted to let you know that I did use the OpenG library and was able to reduce the complexity of my VI tremendously.
Message 5 of 10
(6,234 Views)
I was happy to help 🙂
Message 6 of 10
(6,224 Views)
It's really helpful.
But there is another quention, how to save the front panel values and restore it on different VIs?
For example, the main VI use some confire values like hardware port, report path and so on, when we want to change it, we will use Menu bar--Config event and user interface to reconfirge them, and then save it. After restart the main vi.exe, it should restore the values that confired at last time, not press Menu bar--Config- restore event.
How to realize it?
Thanks.
WILL I AM
Message 7 of 10
(5,129 Views)
How to realize it?
Thanks.
I do not understand what is the question actually. You should just program easily what you described. Like you can programmatically save/restore settings using the Event structure...
Message 8 of 10
(5,121 Views)
Just do the load settings as part of the VI's initialization.
Message 9 of 10
(5,118 Views)
Yes, you are right.
I made a logic mistake.
The "save and restore front values functioning" should in the Main Vi, not in the "Configure user interface vi".
It works now.
Thanks.
WILL I AM
Message 10 of 10
(5,102 Views)
