04-13-2006 12:51 PM
I hoped that someone from NI would go on in documenting X-controls.
The dual mode thermometer is a nice example but not enough to get a good idea of what is going on.
e.g. Which events can be handled by an Xcontrol, and what is the exact meaning.
e.g. LabVIEW calls these events when someone clicks somewhere, what is the order of events calling my Xcontrol.
some simple questions and hoping for more background and more examples
Although I made it to a LabVIEW Architect and champion, I know I have a lot to learn
04-13-2006 03:35 PM
e.g. LabVIEW calls these events when someone clicks somewhere, what is the order of events calling my Xcontrol.some simple questions and hoping for more background and more examples
Maybe a webinar about them with some examples that can be developed and/or downloaded. NI is doing all sorts of customer education and this would be a great topic for a presentation.
Bob Young
04-14-2006 09:14 AM
04-14-2006 11:33 AM
ztyaner11 wrote: Why is it improper to make a control in the Xcontrol blinking?
Have you tried making an xcontrol property for this instead?
Albert Geven wrote:I hoped that someone from NI would go on in documenting X-controls.
What's primarily needed is a richer set of xcontrol examples in the example finder.
Xcontrol are a somewhat advanced feature and their complexity arises from their flexibility. I am OK with the current choice to place all instructions inside a blank xcontrol as comments, users just need to read and understand them. 😉 Also, the online help contains about 14 pages of instructions.
Then there is also the excellent xcontrol application note. 🙂
Maybe there should be a discussion section of misconceptions, caveats and typical beginner mistakes.
04-14-2006 02:14 PM
Let me know if you have questions. (And yes, the attached file is a true zip file).
04-14-2006 10:06 PM - edited 04-14-2006 10:06 PM
Thank you for your warm-hearted help, maybe I made a mistake in using Xcontrol, But I already implemented a large system with Xcontrol, in the system I need to monitor and control several VMECrates(each crate with same function and facade), my idea is integrating all the functions and user interface(with several indicators and controls) in an Xcontrol so that it is easily to add or remove a crate from the whole system but with nearly no change to the whole system block diagram.
Yes, it's possible to use background color as alarm caution, but will that be better if the indicator blinks when alarm happens?
So I just want to recommend if the Xcontrol can run in an independent thread once it start to run. Maybe this feature can be wraped in another kind of control in the next version of LV, eg. Ycontrol?![]()
帖子被ztyaner11在04-14-2006 10:07 PM时编辑过了
帖子被ztyaner11在04-14-2006 10:12 PM时编辑过了
帖子被ztyaner11在04-14-2006 10:13 PM时编辑过了
