How to end any application from task manager?
We use excel in our project but when we close the project excel is still remained open in task manager creating a problem when project is opened and closed several times.
Message 1 of 8
(3,822 Views)
Accepted by Anant9
Hi!
See the bottom of my post here
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 2 of 8
(3,812 Views)
Find the attachment which closes the application.
Roopesh
Message 3 of 8
(3,801 Views)
What is the advantage of all those CLFN calls over the System Exec method?
Message 4 of 8
(3,786 Views)
This helps in closing programs which is running in the Processes. So i suggested the above.
Roopesh
Message 5 of 8
(3,765 Views)
Doesn't taskkill do the same thing? I'm not saying your solution is wrong - I'm just trying to understand what the advantage is of having the overhead of all those CLFN calls over a single System Exec that calls taskkill, an approach that has been suggested many, many times in this forum (and is what Even shows).
Message 6 of 8
(3,741 Views)
Thanx... it worked...!
Message 7 of 8
(3,732 Views)
thanx
Message 8 of 8
(3,731 Views)
