How to increase the row spacing between tree items in a modern tree control
I have a VI where i have used a tree control from the modern pallate, I need to increase the space between tree items. and should be maintained even if I programatically Add or Remove tree items
PS:  "AutoRowHt " Property doesnt seem to help here
(3,240 Views)
Accepted by swpo
Unfortunately I didn't have time to play around with whether or not this propgates to new programmatically created entries in the tree control, but if not, you could always just re-run this section of code (or specify the specific row since you'll know the index of the inserted element).
Specifying -2 into the Row Number property will specify the change is to be made for all rows in the tree.
(3,208 Views)
Thank you 🙂
I shall build my code around this logic  🙂
(3,173 Views)
