05-09-2008 11:08 AM
When you state that the two test worked, are you referring to 5 V and a 0 - 5 V sinewave from an AO to an AI? Did testing your code (slightly modified) without the current sensing resistor work? If so, please describe in detail how the application was setup.
For example, I output a signal varying from 1 to 5 volts on an AO and measure it differential on an AI (just like I would have after the resistor). I was using the same code, scale and configuration settings.
If we can verify that the card is not working other than just with this code, I would suggest returning the device for repair. However, I would like to make sure it is the card and not the current sensing setup. Please also post your code or relavant section of code if needed.
05-09-2008 12:30 PM
05-09-2008 12:34 PM
