How to solve Error -1074396080 occurred at IMAQ array to color Image
Hi AnkitRamani,
Can you please post your solution? I have the same problem when using Kinesthesia and NI Vision. I tried multiple fixes and still get the same error when converting from Array 24U to IMAQ Image.
Thanks in advance.
Message 21 of 22
(1,404 Views)
FYI, I solved the problem using an adittional IMAQ create for the VIssion Assistant Dst input.
Regards.
Message 22 of 22
(1,371 Views)
