04-28-2005 08:15 AM
05-01-2005
02:51 PM
- last edited on
10-07-2026
06:53 AM
by
Content Cleaner
Hello MSARIKOC,
For the Example Finder to run properly, the NI Service Locator and the Help Server should be running. These services open TCP/IP ports to communicate with NI Example Finder and the LabVIEW Help. So I would suggest restarting these services.
You can restart the Service Locator by opening up the Windows Services window by going to Start » Control Panel » Administrative Tools » Services. In the list of services you should see: NI Service Locator. To restart this service, right-click on the entry and select Stop. Wait a minute until the service has stopped and then right-click and select Start. Restart LabVIEW and see if you can launch the example finder.
In order to enable the HelpServer, navigate to C:\Program Files\National Instruments\LabVIEW 7.0\resource\system and run the HelpServer.llb. On the front panel of the Set HelpServer Config Settings__NATIONAL INSTRUMENTS.vi you will see a boolean control to enable the server. Turn this switch on and run the VI. The LED indicator in the HelpServer.vi will turn on.
Also, try the suggestions given here (last 3 lines):
You do have the examples installed at C:\Program Files\National Instruments\LabVIEW 7.1\examples, correct?
Best of luck!
Shakhina P.
Applications Engineer
05-02-2005 01:37 AM
05-03-2005
01:59 PM
- last edited on
07-22-2026
04:17 PM
by
Content Cleaner
Hi MSARIKOC,
Have you tried disconnecting your personal firewall? If the same problem happens even after you disconnect the firewall, I would suggest completely uninstalling LabVIEW (including the Run-time engine) and doing a fresh reinstall again. Do you have any other NI software that uses NI Example Finder (like CVI)?
Also, following the URL given in this document What Is The NI Service Locator And How Do I Troubleshoot? get a view of the connections that are being made to the NI Service Locator and see if you get a similar report (HelpServer, NIExampleFinderServer entries might be of interest).
Good luck!
Shakhina P.
NI
06-02-2005 11:58 AM
03-06-2006 08:47 AM
Did you solve this problem right now? I hope so because I'm encountering the same one for a few days.
Waiting for your answer!
03-06-2006 08:49 AM
I hope you solved your problem reagrding at NIExampleFinder! I encountered the same difficulty and I would like you to help me.
What can be done to slove this problem? Where is its origin?
Waiting for your answer.
03-07-2006 12:30 AM
03-07-2006 02:20 AM
03-08-2006 02:12 AM
