Incorrect timestamps
exactly....when I am not recording, i.e. the FALSE case, then, the parameters are : Number of samples  : 500
        Frequency :  50 Hz
        Timeout :  20 sec
and when I am recording, i.e. the TRUE case,then :
        Number of samples  : 30
        Frequency :  10 Hz
        Timeout :  10 sec
I think, when I switch from FASE to TRUE during the run, the frequency changes to something else and hence I am getting the intermediate values.
I don't know the reason behind this.
Do u have any idea ?
Message 11 of 15
(848 Views)
I'm not sure why except the Express VI may be in the middle of taking measurements with the old (false) settings when you hit record.  It should finish what it's doing, but you should see these values recorded as well.
Have you tried using the same settings for both cases?  Also try recording the measurements using the false case settings as well and see if there is a difference with the timestamp.  You may also want to try using the DAQMX VIs instead of the Express VI.  These will give you more control.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 12 of 15
(846 Views)
Accepted by chirag.joshi
magic...when I used the same parameter while recording and not recording, the problem was solved....
now I am getting results exactly at 3 sec interval although I hit record during the run...
I don't completely understand why, but thanks a lot anyway for the suggestion.
I don't have experience with DAQmx but I will try this option too for future applications..
Message 13 of 15
(842 Views)
Don't forget to mark the correct post as Solution.
Message 14 of 15
(839 Views)
alright...thanks for pointing it out.Smiley Happy
Message 15 of 15
(836 Views)
