‎04-06-2017 03:10 PM
Hello!
Just moved from 2014 to 2016 my FPGA projects and faced an error:
Error -61499 occurred at niFpgaCompileWorker_AnalyzeTimingPaths.vi<-niFpgaCompileWorker_CheckForErrors.vi<-niFpgaCompileWorker_JobComplete.vi<-niFpgaCompile_Worker.vi:6460001
Additional Information: TimingReportFileNotFound: exception type "NI.LV.FPGA.Xilinx.TwxParseFileNotFoundException".
Details:
How can i beat this error?
‎04-06-2017
04:16 PM
- last edited on
‎09-16-2026
10:02 AM
by
Content Cleaner
Hello Crowbar,
Here are some links with different troubleshooting options that i think might help you
http://digital.ni.com/public.nsf/allkb/5B8827503F7D90F386257BEA002D8E99?OpenDocument
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019M8ESAU&l=en-US
Regards.
‎04-07-2017 02:52 PM
These don't work. I've tried to reinstall all software components - the result is still the same.
Error arises on finalizing file step and is based on a report file missing.
My CLIP uses additional timing constraints and they worked normally in 2014 on the same target.
‎04-11-2017 10:59 AM
I am getting the exact same error, hopefully a fix will be found soon
‎04-12-2017 05:23 AM - edited ‎04-12-2017 05:23 AM
What can I say for now:
1) I was able to fix this error by removing some timing constraints in my CLIP's xdc and part of vhdl code which worked in 2014
2) Definitely cRIO timing constraints and rules of there forming for the given chassis have changed a bit since 2014 release (clock groups and there relations) cause i see clear timing violations in compilation logs. But this errors weren't reported as timing fails during compliation - instead internal FPGA module error was thrown!
