05-19-2008 10:30 PM
05-19-2008 10:53 PM
05-19-2008 11:17 PM
05-19-2008 11:43 PM
05-20-2008 12:35 AM
05-20-2008 12:46 AM - edited 05-20-2008 12:47 AM
Hi Simmy,
you can use the "array to spreadsheet string" function. You only need to send your data once each interation. ![]()
Mike
05-20-2008 01:03 AM
05-20-2008 01:10 AM - edited 05-20-2008 01:12 AM
Hi Simmy,
and what exactly did not work?
See the attached example. It do the same, but without TCP/IP and it works like i expect it.
Mike
05-20-2008 01:14 AM - edited 05-20-2008 01:15 AM
Hi Simmy,
your picture shows not the same.
Right click on your tunnel element on the loop and select "disable autoindexing".
Mike
