Is it possible to receive data via RJ-45 like how data is received via RS-232?
I can understand the pressure you are under. LabVIEW is marketed (and rightly so) as a programming language that is easier to learn than the traditional text based languages. Easier is a relative term though and just like C++, VB, etc., there is a learning curve that can be pretty steep.
Keep plugging away and keep posting with your problems.
Message 21 of 35
(989 Views)
It's working now! after i change to read from spreadsheet, all the row are able to be sent line by line! but it stopped after it finish sending the text file, i wonder what did i do wrong LOL.
Message 22 of 35
(986 Views)
could you please help me see what is the problem? my RS-232 will keep sending the files non stop, from the top to the bottom, then repeat itself, but this program doesn't, what could be the problem?
Message 23 of 35
(983 Views)
I think I gave you some bad advice about only reading the file once. For a simple fix, put the Read From Spreadsheet inside the while loop like the original RS-232 example.
Message 24 of 35
(980 Views)
i tried that, and got this error instead...
Message 25 of 35
(976 Views)
Hi Simmy,
you can use the "array to spreadsheet string" function. You only need to send your data once each interation. Smiley Happy
Mike
Message Edited by MikeS81 on 05-20-2008 07:47 AM
Message 26 of 35
(972 Views)
i followed exactly like what you did, and it didn't work at all....
Message 27 of 35
(964 Views)
Hi Simmy,
and what exactly did not work?
See the attached example. It do the same, but without TCP/IP and it works like i expect it.
Mike
Message Edited by MikeS81 on 05-20-2008 08:12 AM
Message 28 of 35
(961 Views)
it will work when i do it this way(refer to attachment), but it still does not run the spreadsheet constantly, i need it to keep repeating the whole process over and over again... until i decide to stop this program...
Message Edited by Simmy on 05-20-2008 02:12 PM
Message 29 of 35
(960 Views)
Hi Simmy,
your picture shows not the same. Smiley Happy Right click on your tunnel element on the loop and select "disable autoindexing".
Mike
Message Edited by MikeS81 on 05-20-2008 08:15 AM
Message 30 of 35
(956 Views)
