Keithley 2400 errors
Did VISA installed correctly? No errors or warnings?
Message 11 of 16
(1,836 Views)
I also want to use labview to control keithley 2400, I want to ask how can you set the delay of each value of volt?
Message 12 of 16
(1,780 Views)
Samule,
Are you using VISA or the Keithley 2400 instrument driver to communicate with this instrument? If you are using the Keithley instrument driver, there may or may not be a built in function and you would need to explore the set of available functions to find out if there is a function to se the delay value. If you are using VISA, you would need to check with the instruments instruction set to find out what the command should be to set this value.
Raj
Applications Engineer
Message 13 of 16
(1,758 Views)
Could someone help me to verify the error in my vi? It was ok with Labview 6.1. However, it shows an error: unterminated error when runing it. The error is from the reading of the data. What could be the possible reason?
Loc
Message 14 of 16
(1,547 Views)
Sorry, the above question is for keithley 2400
Message 15 of 16
(1,546 Views)
You need to update your firmware revision to C30 or C32.
Message 16 of 16
(1,480 Views)
