LV Compare error with Tortoise Git
Hallo,
I have just started using version control with Tortoise Git. I changed the Git settings to use LV compare and merge for diff and merge of tortoise git and made a change to a VI after a commit to see the difference. I incur a problem with launching LV compareLV compare error.JPG
 I added .vi extension to advanced diff settings with external program as "C:\Program Files\National Instruments\Shared\LabVIEW Compare\LVCompare.exe" %mine %base -nobdcosm -nobdpos
Message 1 of 12
(5,856 Views)
Did you check to verify that LVcompare works outside of TortoiseGit?
Message 2 of 12
(5,844 Views)
It may not be the problem you are encountering, but LVCompare will run in the last context which was active in LabVIEW (which is a real PITA).
Could it be that you were working on a RT target before launching a compare?  This behaviour of LVCompare and LVMerge is extremely annoying because there's no reason whatsoever to run either of these on any target other than "My Conputer".  If this helps, please give Kudos HERE.
Message 3 of 12
(5,811 Views)
I tried it with command prompt and the same error recurs
Launching LVCompare.vi  from C:\Program Files\National Instruments\Shared\LabVIEW Compare\supportVIs\_prolvcmp.llb
gives the following error
An error occurred while running LVCompare.
NI_LVConfig.lvlib:Load.vi<ERR>
C:\Users\Z003W3YA\AppData\Local\Temp\LVCompare.ini
Message 4 of 12
(5,790 Views)
I am not working with Real Time at the moment
Message 5 of 12
(5,788 Views)
Why are you running the VI, there's an EXE isn't there? Under "National Instruments/Shared"....
Message 6 of 12
(5,785 Views)
I am trying everything to understand the problem. The exe causes error on launch and in command prompt with parameters
Message 7 of 12
(5,783 Views)
When you look at the error, it says it can't opent he ini file for settings.... could permissions on this folder (possibly on a network drive) be part of the problem?
Message 8 of 12
(5,781 Views)
The error occurs in my work computer where I use LV full development system whereas it does not occur in my personal computer where I use LV professional development system.
Could the version be the source of problem?
Message 9 of 12
(5,765 Views)
I get that error from an MSYS2 terminal "git diff" with LabVIEW Professional Development System Version 2023 Q3 (32-bit) 23.3.1f1. C:\Users\<user.name>\AppData\Local\Temp\LVCompare.ini does not exist (I have permissions and can create the file manually). The error message can be scrolled down to see the following.
<b>Complete call chain:</b>
NI_LVConfig.lvlib:Open Config Data.vi
LVCompare.vi
Message 10 of 12
(2,412 Views)
