Labview serial connection issue.
Accepted by skie
VISA 17 would work with LV 16.
There is no VISA 5.8, so I don't know where you got that from looking through your installed programs.
Your MAX shows NI-VISA 17 installed.  Also LV 16 32-bit and 64-bit.  I think the problem is that you are using LV 2016 64-bit because your LabVIEW icon is white.  That means you don't have the 64-bit version of the VISA drivers installed.
is there any reason you are using 64-bit?  You should be using 32-bit unless you have special needs like using lots of memory for vision applications
Try starting LV 32-bit and run your VI.
Message 11 of 15
(1,561 Views)
Just out of curiosity.  (I hate asking this but...) did you consider following the hyperlink shown in your picture?
Here it is
See the Link?See the Link?
Did you install VISA support for LabVIEW 64 bit?  Doe it work for 32 bit?
Message 12 of 15
(1,557 Views)
Ended up removing labview 16 and installing 17. This time I checked every box on the options to install. Runs with no errors now but the "response" window in simple serial VI doesn't populate. When I run continuous serial VI I get overflow errors on the "response" window.
Message 13 of 15
(1,525 Views)
Probably an issue with the commands you are sending.  Or your baud rate, or stop bits, or something else.  But we can only guess since no code is attached and we don't know anything about how the Arduino based system is programmed.
Message 14 of 15
(1,516 Views)
Likely due to the use of the Bytes At Port not giving enough time for the instrument to respond.  You should instead just tell the VISA Read how many bytes you expect in the message.
You are getting data faster than you are reading it.
In the end, we cannot help you unless we know exactly what the protocol is for the messages going back and forth.
Message 15 of 15
(1,505 Views)
