Lapsed time incorrect format on seconds
The attached VI keeps tract of elapsed time and I am having a problem with the format in the seconds section. It gives me 3 digits and does not count the seconds correctly.
I would like to have only 2 digits for the seconds and count correctly as 01, 02 .. 09, 10, 11, . . . 59  (seconds section).
Could someone suggest a change to attached VI?
frn
(3,565 Views)
Accepted by frn
The reason you are not seeing the right number is that the value you get out of the last Quotient & Remainder Function is NOT the seconds, but MILIseconds.
Add one more Quotient & Remainder with a 1000 as y. Then take the floor(x/y) as your seconds.
(3,561 Views)
If you do not need a string output, consider subtracting timestamps and formatting the numeric display of the difference as Relative Time.
Lynn
(3,553 Views)
Thanks dkfire,
It works great!
frn
(3,537 Views)
Thanks Lynn for your input, but I need string as an output.
frn
(3,536 Views)
