Lowercase to Uppercase and Uppercase to Lowercase
Thank you everyone for your help. I got more than I thought. Smiley Happy
Message 31 of 38
(2,031 Views)
So for 'always best performance' i take it we'll add an Array size on the U8 connected to a case with 1 parallell option and one normal, or will it be as fast if you use a parallell loop with N=1?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 32 of 38
(2,008 Views)
/Y
It probably won't be that easy to find a globally optimized solution that has the correct crossover point under all conditions. CPU architecture (cache sizes, number of cores, etc.) probably makes a difference. I would go with a plain loop because strings are typically short and that extra decision might even slow things down. 😄
Message 33 of 38
(1,991 Views)
Just thought I would give it a try.
Message 34 of 38
(1,944 Views)
You don't need the AND and the second Select function. If its input is TRUE, it means neither the To Uppercase nor the To Lowercase changed anything, which implies the bottom element is the same as the top element. It also means you don't need the lower Equal? check.
Message 35 of 38
(1,938 Views)
Yep, you are right.  Nice job!
Message 36 of 38
(1,935 Views)
Hello! Could you tell me what the name of the function is? Where can I find it?
Message 37 of 38
(1,816 Views)
swap values
("Application control...memory control" palette)
Message 38 of 38
(1,808 Views)
