Mouse Cursor Bug over vertical Scrollbar in a String Control & Indicator
Hello All,
Working with LabVIEW 2017 f2 on Windows 7 I experience the following problem:
When I move the mouse cursor in a string control or indicator with visible scrollbar from the text area over to the scrollbar, the mouse cursor doesn't change from the text-Cursor to the expected Arrow. When coming from outside the controls area to the scrollbar it remains the arrow until the cursor enters the text area.
I do not see this with LabVIEW 2015.
Is this reproducable by you?
Greets, Dave
(3,547 Views)
Yes, reproducible. Same for horizontal scrollbar.
There seems to be a small difference between run time and edit time (although could be coincidence):
Run time: cursor will not change when entering scrollbar.
Edit time: cursor is set to text edit icon when entering scrollbar.
Happens with all strings: Modern, Classic, System...
(3,515 Views)
Accepted by daveTW
It was already reported (CAR# 667716).
(3,487 Views)
