Moved to a new computer and now my User Libraries does not show up on function palette
I'm currently moving everything over to my new computer and I have everything done except for some LabVIEW things. Getting my function palette correct is one of these. I was able to copy over other custom tabs, but the user library does not show up. Is there something I am missing as to why it will show up under the settings, but then not in the program?
(1,756 Views)
Did you copy the content of user.lib to the new computer?
Santhosh
Soliton Technologies
(1,744 Views)
Yes I did as well as the palettes folder under LabVIEW Data
(1,740 Views)
Whenever I move LabVIEW to a new computer I copy the entire user.lib directory and sub-directories under it.
EXECPT the ones that start with _ (_express and _probes).
Then I delete the dir.mnu file and let LabVIEW rebuild it.
=== Engineer Ambiguously ===
(1,730 Views)
Did you copy your LabVIEW.ini file?
Jim
(1,729 Views)
Well I was dumb. It was there and just hidden. When I clicked the down arrow it was there and was just not enabled to be visible.
(1,716 Views)
Well, maybe it's not so dumb.  I mean, I've done that before.  Okay, so maybe it is dumb after all.  😄
Bill
CLD
(Mid-Level minion.)
(1,694 Views)
