05-16-2025 04:03 PM
I understand the fundamental issue or concern about having multiple event handler trying to do things. I am also realizing that the example I put together might have been a too-simplified representation of the real problem. I'm going to try to see if I can address it by using a single event handler and I'll ask again if I fail. Thanks!
05-16-2025 04:22 PM
These are event structures with event cases.
I would not use the term "event handler" to avoid confusion.
