Multiple event handlers in state machine
I understand the fundamental issue or concern about having multiple event handler trying to do things. I am also realizing that the example I put together might have been a too-simplified representation of the real problem. I'm going to try to see if I can address it by using a single event handler and I'll ask again if I fail. Thanks!
Message 11 of 12
(129 Views)
These are event structures with event cases.
I would not use the term "event handler" to avoid confusion.
Message 12 of 12
(124 Views)
