My labView code works fine in an interactive mode. Neither EXE of DLL works ???? I am using 6.0i although the code was written for 5.0..??
Need to know what doesn't work. Are you calling any VIs dynamically? Are you attempting to read from files? There are a lot of different things that could cause a built application to not work.
(2,681 Views)
When you create an executable or shared library from LV, it requires the LV runtime engine of that version. So, if you created the EXE or DLL in 5.0, you will need to install the 5.0 runtime engine to run it, or you can create a new EXE/DLL in 6.0. (The LV development system will know how to update the VIs from 5.0 to 6.0, but not the runtime engine.)
(2,681 Views)
