.NET Http/Https Get document
Note that there are different security protocols for SSL.
These examples here work only for the TLS protocol which is the default.
But if the server doesn't support TLS you won't get a response.
You can change the protocol by adding a property node for the SecurityProtocol of the class System.NET.ServicePointManager.
A possible value would be "Ssl3" for example:
http://msdn.microsoft.com/en-us/library/system.net.servicepointmanager.securityprotocol.aspx
Message 11 of 21
(5,944 Views)
I want to download an xml document that has a https url, so this thread should really help me accomplish that. Unfortunately I can't even find the .NET assembly that contains the WebRequest methods. Anayone know which assembly I should choose in the Labview Class browser to find these methods?
BTW. the code snippet has the method nodes removed when I drag it into Labview. Maybe that means that the assembly is not present in my installation?
Thanks!
Aart-Jan
Message 12 of 21
(5,932 Views)
Hi, I'm trying to do the exact same thing with no success any ideas?
Message 13 of 21
(5,461 Views)
What version of .NET is installed ?
Message 14 of 21
(5,455 Views)
The webpage i'm trying to parse is: https://192.168.254.254/XML/DeviceInfo.xml where the IP is the device I'm trying to query. I was wondering if there's a way to do the File - Save As of IE explorer programatically?
I'm using LabVIEW 2009 and .NET Framerwork 3.5 SP1
Message 15 of 21
(5,453 Views)
If you are trying to store the contents of the web page, you could use HttpResponse. I've not done the "Save As" ...
Message 16 of 21
(5,446 Views)
I end up doing this (see attached VI). Seems to works, but you need to run it at least twice to get the proper text on the indicator "inner text" Any idea why? or any improvement?
I got this idea from one of the NI Examples.
Thank you!
Message 17 of 21
(5,443 Views)
Hi ethmx,
Have you tried running your code with highlight execution turned on? Does the 'inner text' indicator populate correctly on the first try withe exeuction highlighting turned on?
Cheers,
Andy C.
Applications Engineer
Message 18 of 21
(5,421 Views)
I'm also very interested in seeing this work with .NET .  HttpRequest > write to excel file > save to web server..
Message 19 of 21
(5,406 Views)
i was using your fantastic Example To make a HTTPS POST .
But now I have to do to log into a site What use HTTPS , dove I can INSERT into Your "VI" The credentials ( username and password) ???
Thank you
Message 20 of 21
(5,224 Views)
