NI 9263
Is there a way to programmically change the resolution of an analog out to a lower limit? The 9263 is +-10, 16bit. I'd like to alter this so I can decrease my voltage limits, thus getting a better resolution.
(4,341 Views)
Not according to the specs, it has only one range
https://www.ni.com/docs/en-US/bundle/ni-9263-specs/page/specs.html
(4,336 Views)
Could I setup two channels? One with a hardware voltage divder and one without. I could then tell labview to use one channel at certain voltage levels?
(4,333 Views)
Is there any Analog Out device that NI has that can output voltages from 10mV to 20V? The 9263 only has a 0.05V minimum
(4,326 Views)
Hi skinner,
Well, the NI9263 is capable to do so. With an accuracy of 14mV as stated in the specifications
Really? Where does it say so?
Couldn't find that in the specs…
(4,300 Views)
Yea, that was my mistake. The 9263 will work for my application.
(4,276 Views)
