Need help in vi conversion from LV 7.1 to LV 2017. Window
timephase>> Have you even tried to look at the DAQmx examples? Where do you get stuck? I doubt someone will do your work for free when you have not even looked at the examples.
Note that you, of course, need to install the DAQmx driver to able to use your board with Labview 2017 regardless of who will develop your code.
Message 11 of 20
(1,532 Views)
I did not ask about doing it for free.
Message 12 of 20
(1,530 Views)
timephase>> You are right. Sorry, I read your message too quickly.
Message 13 of 20
(1,506 Views)
Hi timephase,
after installing DAQmx you will get a lot of examples for free! I'm sure there is an example showing how to configure a measurement with a predefined sample rate, that starts with a trigger signal...
DAQmx also supports to save data directly to tdms files! And yes, there also is an example demonstrating this feature...
Message 14 of 20
(1,497 Views)
Thank you. I will try it. Still would like to know if someone can do it for me. Just in case I will mess up or it takes too much time. Let me know if you can do it for me and how much it will cost. My email: coatings@gmail.com
Thank you!
Timephase
Message 15 of 20
(1,493 Views)
Hi timephase,
there is a special forum for job offers. You should post over there!
Message 16 of 20
(1,494 Views)
Thank you GerdW! Can you provide the link to the forum where I can place this and other jobs?
Message 17 of 20
(1,490 Views)
Hi timephase,
yes, sure:
Message 18 of 20
(1,478 Views)
Accepted by timephase
... or you could follow my suggestion (very early post on this question) and drop the Dreaded DAQ Assistant from LabVIEW 2017 on an empty Block Diagram and Follow the Directions.  From what I saw of the strange code you posted, this should be able to write most of the code for you (you may need to add the Graph/Chart Indicator).
Message 19 of 20
(1,474 Views)
Thank you Bob for the details! I will try.
Message 20 of 20
(1,466 Views)
