Newbie question: Replace an array element with a new value
I have a 2 dimensional string array where the second column of data contains dates. I want to change the date data from day month year to year month day. How can I do this?
Message 1 of 11
(3,258 Views)
Index out the column
Format to timestamp
format back to string
replace column
Message 2 of 11
(3,247 Views)
Thank you. I was too general on the description of the date format
Current date field example: 05 Feb 2012
Replaced date field example: 2012 02 05
Does your example address this format?
Message 3 of 11
(3,239 Views)
not exactly but a minor mod to the format specifiers would
That does it
Message 4 of 11
(3,225 Views)
Would you mind posting the vi, as the functions are not immediately familiar?
Thank you
Message 5 of 11
(3,218 Views)
Check the edit above.  It took a minute
Message 6 of 11
(3,213 Views)
Harry,
Jeff's picture is a code snippet.  Drag the picture to your desktop and then drag it into a VI.  Voila.
aputman
Message 7 of 11
(3,199 Views)
That is cool. Thanks!!!
Message 8 of 11
(3,195 Views)
@aputman wrote:
Harry,
If you look at the edit time in the post it makes more sense.  I posted- ran off to whip up a quick example (Couldn't remember the difference between %B and %b) and was delayed with the edit crossing Harry's post-  so there was no example when he read it the first time.
(These things sometimes just need to be explained to make any sense)
Message 9 of 11
(3,194 Views)
Welcome,  Next thing you know you'll be giving Kudos and marking solutionsSmiley Wink
Message 10 of 11
(3,188 Views)
