Nigel
when trying to sign in to the Nigel™ AI application, I receive the following error message: "You are not authorized to connect to the Nigel AI. Please contact your administrator." The LabView is registerred and activated, but access to Nigel appears to be blocked.
Could you please advise me on the next steps?
Message 1 of 14
(3,949 Views)
Nigel is only included in LabVIEW professional and higher. Not in "Base" of "Full" (details). What edition do you have?
Message 2 of 14
(3,922 Views)
Access to Nigel requires not only LabVIEW Professional but also having an ni.com account with the entitlement. Reference: How to Access, Activate, and Troubleshoot Nigel for LabVIEW and Teststand - NI
Christina Rogers
Principal Product Owner, LabVIEW R&D
Message 3 of 14
(3,909 Views)
I have installed LabVIEW for Academic Use AVL, Perpetual license.
Message 4 of 14
(3,894 Views)
"Academic Volume License (AVL) holders may qualify if SSP is included and only user who is registered as technical contact will have access to Nigel." How to Access, Activate, and Troubleshoot Nigel for LabVIEW and Teststand - NI
Christina Rogers
Message 5 of 14
(3,886 Views)
Ok, thanks for the explanation.
So, if I'm not a technical contact, I cannot use the Nigel which is by default installed in my PC with LabView...
Message 6 of 14
(3,870 Views)
Interestingly I get exactly the same error and I cannot get a good answer out of NI  support. I have the partner program software and I'm the only developer so I should be registered as the end user but I have no way of seeing that I am actually the end user. in my account with my name it shows the software registered to me so I assume I am the end user. But should there be a flag that actually says the words 'end user'? Thanks !
Message 7 of 14
(3,814 Views)
I reached out to our Academic team, and NI's intent is that our academic customers should have access to Nigel AI, but there are technical issues with how our licenses currently work that prevent automating access.
Please refer to Technical Support Access for Academic Volume Licenses (AVL) - NI. I apologize for the inconvenience, but the current solution is that getting technical support access will also enable you to login to Nigel. We are working on addressing this issue in a future release.
Christina Rogers
Message 8 of 14
(3,805 Views)
How to Access, Activate, and Troubleshoot Nigel for LabVIEW and Teststand - NI says:
  • Partner Software Subscription:
    • Nigel is accessible if the subscription is active.
    • Ensure the SN is registered in your NI.com account. Kindly refer to Registering a Product for more details.
Christina Rogers
Message 9 of 14
(3,798 Views)
Christina, do you have any information on how this works for partners?
Santhosh
Soliton Technologies
Message 10 of 14
(3,625 Views)
