Not able to change property in property node
Hi
I am trying to configure a DAQmx routine where I record multiple analog channels. I am able to create the routine, but I read that there are some problems with multi-channel sampling (ghosting), so I wanted to avoid this.
How Do I Eliminate Ghosting From My Measurements?:
http://digital.ni.com/public.nsf/websearch/73CB0FB296814E2286256FFD00028DDF?OpenDocument
Which further directs you to;
How Do I Increase Interchannel Delay Using NI-DAQmx or Traditional NI-DAQ (Legacy)?
http://digital.ni.com/public.nsf/websearch/65E7445DB1AA5DC586256A410058697B?OpenDocument
However, when I try to use a DAQmx Timing Property Node, I am not able to change the property (see screenshot). I have tried right-clicking and left-clicking and clicking all over. I think there is something I might not understand, but any pointers would help alot! Chaning between Read/Write does not help
(2,784 Views)
Accepted by livermor
Never mind! Found the solution in the Knowledgebase 🙂
(2,724 Views)
Can you post the link to the KB, which you think is a solution.
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,716 Views)
Of course!
http://digital.ni.com/public.nsf/allkb/A92F81190B730C6686256F3C00609461?OpenDocument
In case that link doesn't work, the title is:
Missing Properties in DAQmx Property Nodes
with Document ID: 3ESBHEL2
(2,697 Views)
