Opening new VI and pass some Data
I was able to open a new window VI using the VI reference. The problem is when I build an executable I have the error: "LabVIEW: (Hex 0x5A5) Open VI Reference no longer matches VIs in memory by filename. A filename is no longer sufficient because the full name of a VI now includes any owning libraries." If I run directly from Labview, it runs okay.
I am building a path using the application directory with a build path, and as I mentioned if I run from Labview it runs okay, but if the executable gives that error mentioned.
I am sending data to the new VI using the VI Invoke Node, with the set Value. Is another better way to perform this task?
Message 1 of 21
(4,237 Views)
If the VI you're trying to open with a reference is compiled into the .exe, then the path to it will include the .exe name as a path element.
e.g: "C:\My App Folder\My App.exe\My Module.vi".
You can use this paul_cardinale_0-1582211053515.png to determine whether you are running from the dev environment or from the compiled app; then construct the path appropriately.
As an alternative, load the VI dynamically.
Message 2 of 21
(4,214 Views)
Place an indicator on the screen of the filename that you are sending to open the vi reference and then rebuild your executable. I believe that this will give you a clue as to what the problem is.
Message 3 of 21
(4,211 Views)
Use the Diagram Disable Structure instead.  You can use the RunTime Engine == True case for when you are running in an executable and the Default case for running in the IDE.
GCentral
Message 4 of 21
(4,202 Views)
I suggest using static VI reference.
Static VI References will also include the VI in the build automatically. When a ref is opened by name or path, you have take care of that.
Even if you have to open a reference (to create a clone), I use a Static VI Reference, and then get the name or path from it to open the reference. The VI is always included, the name will always be in memory.
Message 5 of 21
(4,199 Views)
I will do what in order to check what is happening. Thank you
Message 6 of 21
(4,147 Views)
Thank you. I will try to figure out how to work with this property.
Message 7 of 21
(4,146 Views)
I am new at Labview, sorry...
This feature is very nice. But I think I might find my problem. I am trying to check if the new VI is opened in a new window, so I use something like the attached files.
When I am running under Labview, I get from "idle" to "tun top level". When I am using the executable i always get "bad".
Message 8 of 21
(4,099 Views)
So if I use something like this:
I can get access to the new VI, and don't get errors with the paths.
I will try to use this, approach. thank you
Message 9 of 21
(4,097 Views)
Using Static VI Reference solvess my problem. However, if I press the button to stop the app (the typical one), when I push-it it will stop the app, but the next time that I start running the program I cheking for the "VI > Exec.State" and get "Run top level". If I close the labview and perform everything by hand I get "idle". So my question is, how I can stop the new VI to be loading or something like that?
Message 10 of 21
(4,082 Views)
