Printing front panel comes out blank
I am running labview 8.2 with windows xp. On a vi I want to print the front panel (this vi just contains 3 tables), however whenever i go to file>print> and try to print either complete or just the visible part it always comes out blank. When i try printing to a rtf file it has the 3 tables exactly as i want. i have tried printing to two different printers. Also if i try to just print a simple text box it works fine.  I have tried from both the tool bar and programming it to print with the easy print vi panel, and neither one works.
Any suggestions?
Andy
Message 1 of 8
(3,481 Views)
Here is a copy of my vi. can anyone print this? You don't even have to run it, just print the front panel.
Message 2 of 8
(3,468 Views)
Print Preview looked OK, but all I got was a sheet of grey paper. I added a control of my own and output was still all grey.
Message 3 of 8
(3,453 Views)
Yes, that is the problem I am having to. Atleast I know I'm not crazy. Anyone have any ideas on this one?
Message 4 of 8
(3,450 Views)
Hello Andrew,
You are definitely not crazy as I could not get the front panel to print at first either.  It seems like the file may be corrupt, as I can print many other VI front panels.
After changing the indicator to a control and then back, it seems to work fine.  You may want to try recreating this VI.
Happy Holidays!
Janell R | Applications Engineer
Message 5 of 8
(3,417 Views)
Thanks, I created a new file and it prints now!
Message 6 of 8
(3,397 Views)
Ok, it's back again. I was able to pull out the code and make a new vi and it printed fine. when i put this vi back into my main program it printed blank gray screens.
Message 7 of 8
(3,384 Views)
Hey Andrew,
It looks like that main VI may need to be recreated also - that could be where the corruption is originating.  If this continues, you may want to try repairing LabVIEW (go to Start > Settings > Control Panel > Add or Remove Programs > Change National Instruments Software > Repair) or mass compiling.
Happy Holidays!
Message 8 of 8
(3,361 Views)
