Problem repeating a couple of steps
Thank you, this is very good, but it shows all the three cases all of a sudden. I want to make them to flow, something like the first case has to be shown 2 seconds, then the second one for 2 seconds and the third one the same.
Message 31 of 36
(1,030 Views)
I violated my promise.
@maryus66 wrote:
This is what I am looking for, but I don't understand what you mean with:
"I still do not understand your goal, but the VI in attachment has a nicer output certainly. Would you mind checking it, please? Well, you basically calculate four values in total in your VI. Could you please scratch a graph of the expected output -- so we can see what you expect?"
You said to scratch a graph of the expected output and I have done it, but I don't know what you wanted to say with the first part of the message... Sorry, can you show me the block diagram for your last post?
Did you check the attachment to the message, which you copied the text from? Did it show you any output? Did it match your expectations?
Message 32 of 36
(1,024 Views)
I am sorry, I didn't see it.. But unfortunately I cannot open it because it says you have a newer Labview version and I cannot open it. I will try to search on the Internet and discover how to convert it.
(I have the 12th version)
Message 33 of 36
(1,019 Views)
Accepted by topic author maryus66
Unfortunatelly, you cannot. See the following attachment.
Message 34 of 36
(986 Views)
Thank you very much and I want to apologize again for my inattention. Now it does exactly what I wanted and I'm glad that everything was resolved.
It seems that the changes that I had to make were minor.
Have a nice day!
Message 35 of 36
(968 Views)
You are very much welcome. I am glad I could help.
A minor suggestions to your VI:
- name/label your controls and indicators, then you do not have to switch between the block and front panel so often by double-clicking; and they do not look the same in the code.
Message 36 of 36
(962 Views)
