Programmatically loading values of all front panel controls
I'm trying to save & load all my front panel values. Load is not working. What am I doing wrong?
Message 1 of 31
(6,713 Views)
I see 2 things.
1.  You are feeding the value of the This VI reference into the Value input.  You are not putting in any of the values you saved to the file.
2.  You create a file that is an array of clusters of Name and Variant Data.  When you read the file and unflatten it, you wired in an array of clusters consisting of a string, integer array, and a string.  Your Flattens and Unflattens just don't match.
Message 2 of 31
(6,684 Views)
Still not working!
Message 3 of 31
(6,661 Views)
Here's a modified version following RavensFan's instructions.
In this case, I right clicked on the cluster wire coming out of the Ctrl Val.Get All node, and clicked Create > Constant. I then dragged the constant value to the second case structure, where I wired it to the type input of the Unflatten From String.
Now, you can see that the cluster array created has a Name and Variant Data, as you expect.
As a side note, rather than having a loop with a variety of different cases all being toggled on and off, I would suggest you take a look at the State Machine architecture.
Message 4 of 31
(6,632 Views)
OpenG has a VI that does this for you.  It actually saves the data in a configuration file, making it so you can edit the data in a text editor if so desired.
Message 5 of 31
(6,618 Views)
Another suggestion for OpenG.  It is called Save panel to INI and Load panel from INI and the functions are on the Variant Configuration palette.  Super easy to use (just one VI each) and the output is a human readable text file.  It can be slow for lots of very large complicated data types (clusters of arrays of clusters of arrays) but for the quick and dirty it functions great.
Message 6 of 31
(6,597 Views)
I downloaded both OpenG & MCI but for the life of me I can't get it working! So I tried to modify my code. Save is working but  Loadis not working! I'm LOST
Message 7 of 31
(6,544 Views)
Your datatype you are flattening on the save is a string and a variant.  The datatype you wired for the unflatten in the load is a string, integer array, and another string.  They don't match.
You are writing those values to a Control Value Set node that is deprecated.  Pick that invoke node again for Ctr Val.Set.   You'll see it becomes a string and variant.  Now wire the correct datatype into the unflatten (create a constant from the wire that goes into the flatten above.  Fix the unbundle by name and everything should now be wired correctly.
Then try again.
Message 8 of 31
(6,537 Views)
Message 9 of 31
(6,533 Views)
Could you show us what you tried with those?  For OpenG, all you need are the Read Panel From INI and the Write Panel To INI VIs.  Those two will do everything for you.
Message 10 of 31
(6,524 Views)
