Programmatically loading values of all front panel controls
This is my state machine..load & Save still doesn't work 😞
Message 22 of 31
(1,608 Views)
  1. You still need to learn about state machines. This is NOT a state machine. It does not change its states during runtime. You only specify a single state BEFORE the main While loop, and never change it inside.
  2. You still overusing the "Reinit to Default" invoke nodes. The very reason you wanna use config files is that you want to get rid of such elements.
  3. You have a greedy While loop, I do not see any timing inside, so your computer CPU's will try to run the loop as fast as possible.
In overall, I really recommend to continue with the learning, and see some proper State Machine examples. In a state machine, you have an initialize state, then depending on some conditions, your loop goes through different cases (states).
Message 23 of 31
(1,604 Views)
I am busy now, but if i get some spare time in the weekend, i will put together a small state machine example based on your required steps.
Message 24 of 31
(1,596 Views)
 Looking to do this exact same function. However I cannot download the OpenG library. Is there any other way to get this library? I was able to download the MGI library, but it requires a file form the OpenG library as well.
Message 25 of 31
(1,473 Views)
Why can't you download the OpenG library if you were able to download the MGI library?
Message 26 of 31
(1,465 Views)
I go through the same process, but it errors out saying it can't access the remote server.
Message 27 of 31
(1,460 Views)
Here's an example of what I am getting for an error
Message 28 of 31
(1,457 Views)
Odd.  First thought is that something is wrong with the server.  But I was able to install it just fine to my LabVIEW 2016 version.
Is it possible your corporate network is blocking access to sourceforge?  But there is some communication going on.
Message 29 of 31
(1,455 Views)
Checking on this. I know I had to request access for the download, so maybe they are still blocking parts of this.
Message 30 of 31
(1,442 Views)
