This widget could not be displayed.
Read datas from table
Yes I have appended Termination char.Yes I have read all the explanations and work accordingly.please check the attached VI.
Thanks as kudos only:)
Message 91 of 189
(1,274 Views)
Hi Danil,
"Yes I have read all the explanations and work accordingly"
I doubt you haven't...
I wrote: "So the problem is more related to the data source... Do you send the strings with proper termination char appended?"
So why do you insist of checking the receiver side of your VIs?
Message 92 of 189
(1,271 Views)
I just want to show how the output happens.see the input side
Message 93 of 189
(1,269 Views)
In a particular array index first element have to disappear while second element comes.But here all the 50 elements of input array index are showing in the output array index at the sametime.It does'nt mean all the input elements in one array index of the output array.
Message 94 of 189
(1,261 Views)
Hi danil,
"In a particular array index first element have to disappear while second element comes."
Your receiver VI is creating an array with 12 elements. Each element is containing what is received with one VISA-Read operation (as configured). No disappearing, no appending...
"But here all the 50 elements of input array index are showing in the output array"
You only receive 12 elements as your FOR loop is wired to run 12 times. Which "50 elements" are you talking about?
Message 95 of 189
(1,255 Views)
Please run these VIs.Also the output I got in update continuously.vi is made as default.
Message 96 of 189
(1,254 Views)
Hi danil,
- I don't have 2 COM ports nor the serial cable available.
- There are no default data in "update cont."...
Message 97 of 189
(1,252 Views)
see the edited VIs above.
Message 98 of 189
(1,248 Views)
Made changes as shown in the attached VIs.Now it is not displaying anything in the output array.
Message 99 of 189
(1,238 Views)
Hi danil,
according to your picture it shows:
- your array indicator will show a text, starting with "DDD8DED5EC..."
- you have a timeout error for the Read operation - probably because now you want to read 550 bytes. Why did you change that? 50 as before wasn't big enough?
Message 100 of 189
(1,233 Views)
