This widget could not be displayed.
Read datas from table
Hi danil,
by viewing at your Read-VI I can say it is not reading in reverse order. It is displaying in reverse order!
Think first, then program!
Message 161 of 189
(1,815 Views)
Oh....but..I can't figure it out??Can you please tell me how it can be?
Thanks as kudos only:)
Message 162 of 189
(1,812 Views)
Hi danil,
ever tried to debug your VIs by highlighting? Ever looked at the BuildArray-node closely?
Message 163 of 189
(1,810 Views)
YES,while running VIs with highlight execusion,it is showing TimeOut error.
But...build array node I can't understand the broblem.Will you please help me to figure it out?
Message 164 of 189
(1,807 Views)
Hi Danil,
"But...build array node I can't understand the broblem."
Hmm. Let's think about that: your problem is the order of the strings in your display.
Mabye it is correlated with the order of the BuildArray inputs.
Maybe...
If one could test that, maybe...
If one could figured out, where the newest string should be attach to: end or start of array?
Hopefully there is someone out there thinking about what he has programmed in it's own VI...
Message 165 of 189
(1,800 Views)
Yes I tested it by reversing the inputs but nothing changed.Also why showing TimeOut error while highlight execusion?
Message 166 of 189
(1,813 Views)
Hi Danil,
"Yes I tested it by reversing the inputs but nothing changed."
I don't believe that. There has to be a difference...
"why showing TimeOut error while highlight execusion?"
I would expect a buffer overflow, but not a timeout...
Message 167 of 189
(1,810 Views)
Yes,changed I meant not get the expected output.I got the output as:
Message 168 of 189
(1,808 Views)
Hi Danil,
I spot a problem in your picture: Did you ever notice the double "\\" in the strings? Did you ever think about the reason why they are displayed? Do you really want them to be displayed?
Everything else is working as expected: the strings sent by your WriterVI are received by the ReaderVI and displayed in receiving order...
THINK FIRST, THEN PROGRAM!
Message 169 of 189
(1,803 Views)
Yes..yes I saw that Iam actually thinking about that.Why it is happening?It comes when Iam giving like this:-
I dont want them to display.
Can you please explain it clearly.?
Message 170 of 189
(1,799 Views)
