Running 2 measurements at simultanously.
You've probably answer this question a million times.
But I have these 2 while loops taking measurments, of distance  and water level(using resistance). And independentlythey are working as hoped.
My questions is, what would be the best way of getting them to work in the same VI??
I keep getting  a 5003 and 5006 error when I try running them as is.
Thanks in advance.
VI is attached.
(1,378 Views)
Accepted by Bandit1234
Unfortunately, you cannot, it is because the program that runs on the Arduino can do only ONE TASK at a time, while it is taking measurements of distance (Digital pulse width), it cannot take measurements of water level (Analog voltage).
Even if you program directly on the Arduino, it can run the instructions sequentially and at any point in time, only one instruction runs.
Santhosh
Soliton Technologies
(1,372 Views)
For all the reasons santo_13 mention above something like this is the best you can hope for...
=== Engineer Ambiguously ===
(1,328 Views)
Dear
That's working as hoped. Thanks very much.
(1,319 Views)
