Shared Variables (Booleans)
I have created two shared variables and distributed and deployed them to the distributed systems manager. The VI I am using is interfacing with my cRIO through DAQmx API. I am wondering why whenever I switch the variables to be true, they both still indicate false? Is there something I am missing whenever I am deploying these shared variables?
Thank you
(2,003 Views)
error-1950679034, I've checked the IP Addresses and they are the same.
(1,996 Views)
Accepted by topic author kepham
nevermind problem was solved, duplicate shared variable folder.
(1,994 Views)
