Simulated ring down sine wave
I want to generate a simulated ring down sine wave in Labview.  I can generate a sine wave by using "simulated signal" but I don't know how to multiply this by e^(-1000t) to form a ring down signal.  Thank you!
(3,094 Views)
Accepted by J999000
Why not use simple datatypes. Everything is harder using express VIs.
(These are very crude examples, you still need to do the correct scaling for time and decay constants etc.)
(3,081 Views)
Thanks a lot for your help!
(3,015 Views)
