Stop run after elapsed time
Hi Kwok2,
I've attached a small VI that counts the running time when the Boolean control is True. If False, it pauses the counting and resumes from the paused number when returned to True.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
Message 21 of 25
(1,004 Views)
Thanks Philip,
I figure another way to work with that.
Please take a look at my attachement.
Where else can I place my wait time that will work on delaying the fan override function but yet effect on the emergency stop or off button?
Message 22 of 25
(999 Views)
Hi Kwok2,
I'm happy if you could use any of our suggestions in your application. However, it seems that you need more help writing your VI than troubleshooting certain issues. This approach is not efficient for any of us.
Therefore I will suggest that you don't post a question until you have tried different solutions to solve it, and in that case specify what your procedure was and which part didn't act as you expected. This approach will make it much easier for us to give you the best solution.
If you have the need for additional training, please visit www.ni.com/training for further information or call your local NI Representative.
Thanks!
Message Edited by Philip C. on 03-23-2005 02:05 AM
Thinkbot Solutions
Message 23 of 25
(992 Views)
Hi Travis,
I was looking over this post in reagrds to a question I had about the elasped time vi you posted. I would like to use it in my own vi, however I'd like to have the Elasped Time (from the express vi) displayed in a hour:minutes:second format. That is if 10 seconds have passed it would be displayed as 00:00:10 or if an hour and a half has elasped it would be 01:30:00 and so on. I tried wiring the format date/time string function to this, and adjusting it so it would display properly, but even if the elasped time is under an hour, I still get a "1" in the hour position. (I had to add 180000 to the seconds to get the time to be displayed in this manner, else the function didn't seem to work right.)
Any ideas on how I can get the seconds to be displayed in the manner I would like?
I'm using LV 7.0.
Thanks for the help...
Using Labview 7.0 and 2010 SP1 with Windows XP and 7.
Message 24 of 25
(954 Views)
Hi MAH6281,
In the future, try to start a new thread for new questions so that it wont be 'lost' in the original thread.
Anyway, i have attached an example which will do what you require.
hope this helps
Message 25 of 25
(941 Views)
