The distribute object tools often crashes LabVIEW 2017
Same problem here. LabVIEW 2017 32-bit on Windows 10 64-bit.
LabVIEW freezes very often when I use "Align Objects" or "Distribute Objects" (especially when wires are selected). There are only 140 VIs in my project. Only LVOOP classes come from dependencies (NI Modbus Library, JKI JSON).
The problem is killing me as I use align and distribute functions all the time. Right now, I seriously regret switching to LabVIEW 2017 from 2015 SP1.
Tomasz Czarnik, Fitech Sp. z o. o., Poland
Message 11 of 18
(2,331 Views)
It's the same for me. LV2017 32bit on Win7 64bit.
It's time for Patch 1!
Greets, Dave
Message 12 of 18
(2,326 Views)
Accepted by Blokk
The issue has been reproduced and is being tracked under CAR #656295.
Dániel Fülöp
Field Application Engineer (CLA, CTA)
Message 13 of 18
(2,282 Views)
Accepted by Blokk
Looks like that was a patch released that has this CAR fixed:
LabVIEW 2017 Patch Details
LabVIEW 2017 (32-bit) f2 Patch Download
GCentral
Message 14 of 18
(2,044 Views)
I already had this patch for a while, and I did not experience recently such crashes 🙂
Message 15 of 18
(2,034 Views)
Hello everybody
I have been facing the same problem recently. If the VI was not auto-saved or manually saved, the chances of crashing were high.
I had contacted local NI couple of times about this and I was just asked to reinstall LabVIEW. This was in November.
If a CAR had been raised and solved in October, I am not sure why local NI support did not refer me to this link. I have been meaning to search the forums about this problem and just managed to do it. I had to reinstall twice on one PC. Now I began to see this problem on another system too and ended up at this link.
Regards
Freelance_LV
TestAutomation Consultant
Message 16 of 18
(1,975 Views)
Installing LabVIEW 2017 f2 patch solved this problem for me.
http://www.ni.com/download/labview-development-system-2017/6967/en/
Message 17 of 18
(1,968 Views)
Just for good measure, this fix was included in the 2017 patch mentioned below and it's been included in the 2017 SP1 release.
Message 18 of 18
(1,930 Views)
