USB DRIVER FOR IMAQ
Hi Brad
     I'm sorry to write back so later due to internet failure here in these days.
     I have replace the ImaqDirectShowDll with the DLL that you attached .(USB Foreign OS DLL.zip).
     and this screenshot attached is the error message for XP pro SP2 simple chinese.
    Looking forward to get the patch
    Thank you very much
Message 31 of 197
(11,909 Views)
Here's the Simple Chinese fix...let me know how it works for you.
Brad
Message 32 of 197
(11,903 Views)
Hello Brad,
it works fluently in  XP pro SP2 simple Chinese!
thank your support!
Message 33 of 197
(11,901 Views)
Hello Brad,
thank your support!
                 lpj669
Message 34 of 197
(11,903 Views)
Hi
I have got the same problem. I use omnivision USB 2 Camera (1600x1200).
My OS is WIn XP SP2 (Polish). I try use this camera with Ni Vision 7.1 and evolution version 8.1. I had installed Ni-IMAQ for USB Cameras.
Message 35 of 197
(11,850 Views)
@aftek wrote:
Hi
You need to follow the procedure! In order for NI to know how to add support for your language they need to know the exact string the localized driver is expecting. For this you have to install the NI-IMAQ version 1.1 USB driver, replace the DLL mentioned in an earlier post by Brad from NI with the attached DLL in that post, start a VI in LabVIEW that tries to capture an image and then make a screen shot of the dialog that shows up and attach it to your post.
Of course the whole story is only necessary since MS decided to do the braindamaged thing of localizing a DirectX programming interface to individual languages in XP SP2. Almost like when they localized the DDE commands to their office suite programs a long time ago!
Rolf Kalbermatter
Message Edited by rolfk on 03-05-2006 11:02 AM
Rolf Kalbermatter  My Blog
Message 36 of 197
(11,846 Views)
I had installed NI-IMAQ, replaced DLL and now I have:
P.r.z.e.c.h.w.y.t...
NI VISION 7.1, LabVIEW 7.1
Message Edited by aftek on 03-06-2006 04:53 AM
Message 37 of 197
(11,823 Views)
Here's the updated DLL with Polish support, let me know if it gives any problems.
Message 38 of 197
(11,211 Views)
If NI is smart enough, they should have made the driver language independant other than easily blaming MS. Other LabVIEW usb webcam toolkit and many directshow applications do not have these problem. It will be too busy to add every languages on the earth to the driver...
Hope you take this as good input... but if I get ONE star for this, I am OK too :womanhappy:
Message 39 of 197
(10,674 Views)
Where can I find new NI-IMAQ USB driver version 1.1.0 ?
I need new feature to control camera resolution.
Thank you
Andrzej
Message 40 of 197
(10,606 Views)
